| | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | At the last swap meet, out at the Ball Park in Arlington, I got a good deal on a bell housing. It was exactly like my old one, but without the crack in it. These things are heavy and, of course, I bought on the other side of the meet. Now that I have it cleaned it up and spray painted I notice it doesn't have the pin on the side for the shifter linkage. Poop. Back to square one. Is this from a truck with a hydromatic transmission? Can the the pin for the linkage be added? Or should I sell this one and look for another? Irwin. Did you ever get the one back from you buddy down at the train museum? Wanta trade?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: May 2001 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: May 2001 Posts: 71 | I went to the hardware store, bought some stock rod of the right diameter, cut a piece long enough to go into the housing and leave enough room for the linkage to mount, and glued it in with JB Weld. Seems to be fine. I hope it holds. Oh, you'll have to drill a hole through the rod at the far end to accommodate a cotter pin. | | |
#5107 01/16/2003 10:45 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | oldbluetruck,
First, let me say that I do not know much about your year/series of truck (55 2nd, I assume).
In earlier HydraMatic trucks there was not a bell housing that was separate from the transmission assembly (thus, the manual transmission bell housing would not be of any use with a HydraMatic).
In manual transmission 216/235/261 trucks, if a factory 4-speed transmission was installed, there was no pivot pin sticking out because there was no need for a column-mounted linkage. Additional useless information: on some earlier 4-speeds there were also no holes on the upper steering column for the 3-speed shifter-bracket under the steering wheel.
As pknauth said, a stock or fabricated pin can be added.
Tim | | |
#5108 01/17/2003 12:40 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | According to tclederman, you'll be out of luck on the bell housing from my old rust mountain because it had the 4 speed tranny. | | |
#5109 01/17/2003 12:47 AM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | oldblue, could you drill and tap a hole for the pin? I think that woud be more secure than using JB Weld. Mike | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Sorry, I was not clear with my response. I think the 4-speed bell-housing had the hole but no pin - but I could easily be wrong.
irwin arnstein - on the driver's side of your 4-speed bell-housing is there a hole for the shift-linkage pivot pin? If not, then one would have to be drilled out (as suggested by slomoe).
Tim | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | i don't have it here, but I can check if its still available. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks for all the info.
Tim, I never thought of the 4 speed. Irwin, if you wouldn't mind checking on the availability of your old bell housing, and if it has the hole or even the pin. I would really appreciate it.
As for mine. I do not have a drill press. It is one of the things I really want - but keep my eye in the classifieds to find a used one.
Does anyone know - if I get the hole drilled in my housing can the old pin be pulled out for use in the this new housing? And how to do it.
#5113 01/17/2003 10:20 PM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I got a drill press, I bet we can make it work. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | | | |
