0 members (),
106
0
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I had to replace the fan relay last night on my street rod. It's one of the little black squares made by "Who shot John?". Measured the current of the new fan (16.4amps) to make sure it didn't exceed the relays rating. The old relay says it is rated for 20/30 amps @ 12v. The new one is rated at 40/50 amps @12v. OK, the question...which one is it. Is it's max current 40 amps or 50 amps? Thanks in advance.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Beltfed, I have no accurate answer, only a semi-uneducated guess. Maybe the first figure is a "make" rating and the second figure is the "break" rating. The dynamics of the load would determine if the relay were appropriate. When a contact is opened while passing heavy DC current, there is a large arc created. Maybe the larger value takes this fact into consideration. If the ampacity of the relay is based on the surface area of the contacts, which I think it is, then it seems like it would be an arbitrary value, so I'm with you, why two numbers. Have you thought about putting a MOV in parallel with the contacts on your fan relay. They quench any arc and prolong the life of the relay by many times. What do I know, I'm just a dumb, retired Millwright. Stuart | | | | | Joined: Dec 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 42 | Ok atomarc, what is a MOV? | | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | The higher rating is a "surge" amperage, what the relay can take as an initial flow as it closes. The lower rating is a "continuous" current flow, what the relay can handle as a constant load without overheating. For instance, the "pull-in" current of a 12 volt Delco starter solenoid on most applications can be 50 amps or slightly more, while the "hold-in" winding only flows about 10 amps. A starter button used to energize that solenoid must be able to carry the momentary surge current without burning contacts, even though the average flow is much less. Solenoids work the same way, initial surge against continuous current. Jerry
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Beltfed, I did a little research and found Wiring Products dot something. Their description of the fan relays indicate two current ratings, the higher one is used if the relay is wired for NO service and the lower value is used when the relay is wired in a NC configuration. With current flowing in the NC arrangement, upon opening, you would get the 'arc flash from heck', hence the lower rating. It's as clear as mud to me. http://www.wiringproducts.com/index...tml&gclid=CNunuoHC-5gCFRxNagodVX7DnAStuart | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | as been discussed here many times before if in doubt use two as the start up current is higher than the run and because this runs a fan that you don't ever want not to have a power sourse for. (weather the fan runs or not depending on the core temp sender). the safe bet and and added cost of $8 at best. but i would think a 40 is plenty enough.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
