| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 13 New Guy | | New Guy Joined: Aug 2006 Posts: 13 | I'm planning on building my 2wd 59 longbed 3200 into a 4x4. I've been told that there may be a difference in the frame between the 2wd and 4wd models during this year, is this true?
I know I can use any axle and I can even change rolling chassis' up to the mid 60's and my body should bolt on. But this is supposed to be a project. With that in mind, I'd like to keep it all original equipment for a true to form 59 4x4 and not some late model pickup with a 59 body on it.
any help would be appreciated Thanks
59 Fleetside Longbed-350 Crate 76 Jeep J20 Ambulance 2007 Wrangler X
| | | | | Joined: Apr 2007 Posts: 456 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 456 | There is no difference between a 2wd and a 4wd frame. I converted a '59 3200 to 4wd in my driveway several years ago with no help. I used a NAPCO front axle and transfer case, which are direct bolt on components. NAPCO advertised that the owner could convert his truck to 4wd in about 3 hours... it took me about 3 days, but I used low-tech tools and took my time. The conversion is as easy as falling off a log. I spent today working on converting my 1950 2 ton truck to a NAPCO 4wd. It's the same process, but everything is heavier!
Task Force frames are completely different than the 60's model trucks, so a direct bolt on ain't happening. Most people shorten, or lengthen a 70's Blazer chassis if they don't care about originality.
If you have any questions let me know and I'll help you figure it out.
Take care, George | | |
