| | | Forums66 Topics128,201 Posts1,057,276 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51059 10/11/2005 5:04 PM | Joined: Nov 2003 Posts: 20 New Guy | | New Guy Joined: Nov 2003 Posts: 20 | Would anyone be willing to tell me how to get the rear brake drum removed from a 1.5 ton 48 chevy truck? I need to replace the wheel cylinder and can not figure out how to remove the drum. Also I need to replace the front wheel bearings and am having a problem locating a supplier. Any help would be appreciated. Thanks Don Mims Cumming, Ga. | | |
#51060 10/11/2005 11:23 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Don, Go the the Big Bolt forum, use the search feature in the upper right corner. Type in "brake drum" and topic with that title will be on the list. It will answer most of your questions. Stuart. | | |
