4 members (52Carl, Gdads51, JW51, Bisbee), 40 guests, and 3 robots.
Topics128,062
Posts1,055,845
Members48,428
#510300 02/25/2009 3:47 PM
I found a T85N 3 speed overdrive for sale. Says it has a R11 tailshaft and that it is out of a ford vehicle from the mid to late 60's. Will this work in my 59 Apache 3200 to replace the old 3 speed Saginaw? Or do I need something totaly different?
1959 Apache 3200, Standard Cab, Big Window, Fleetside, 235/3spd, Original Paint
1964 C20 Standard Cab, Fleetside, 283/Power Glide, A/C, Pwr Steering, Pwr Brakes, NoSpin
If it's out of a Ford then it will not be a direct bolt in, bolt pattern will be different. You would be better of getting a different unit. There is always a few on Ebay if you want to venture there. Can also be found at swapmeets. Bolt pattern is the main thing.
58' 3200 235 3-speed/OD
I guess a SM318 is the direct bolt in?
I would guess the 3-speed you have now is a SM-318.
No?
Professional Novice
From what I have read the SM-318 and SM-326 came with or without overdrives. The three speed that came in our old trucks can not have overdrive added to them because they are different than the above models. At least that is what I understand. The Borg Warner T85N's I have read came mostly in Fords but will bolt up to our old truck bell housings and are the proper length, but I am not sure if this is true or not. Especially after what "Apachefiend" said above. These old overdrive trannys are a little confusing sometimes! I have found a few different one to buy but I don't know which one to get.
Bolt pattern will be wrong, ford used a different pattern. The only GM application I know of for this trans was some Pontiacs used it in the mid '60s. A better choice for an overdrive would be to find an SM 318 or 326 with the Borg-Warner overdrive. Those are a direct bolt in (the 326 is slightly longer). The overdrive unit has to be used with it's companion trans, though, as there are differences in the case and mainshaft to allow for the overdrive.
Other options include the T5 and the GM version fo the A883 (M86Y) trans. Those are both floor shift.
Bill Burmeister
Thanks LONGBOX55! I will focus on the SM 318.
No problwm. Don't just limit yourself to searching for truck versions, the passenger car version is almost identical, and will bolt right in as well.
Bill Burmeister
Anyone,
Does the SM318 or the SM326 have a syncro first gear?
The 318 is non-syncro, the 326 is.
Bill Burmeister
