0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51050 10/11/2005 1:54 AM | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | I'm about ready to put my 235 back together and I notice there are 2 different length head bolts. Does anyone know the proper placement of the head bolts. I'd rather not do it by trial and error. Also, what do they get torqued to? My manual doesn't cover 235's, only 216's. Thanks
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | |
#51051 10/11/2005 3:59 AM | Joined: Aug 2003 Posts: 14 Junior Member | | Junior Member Joined: Aug 2003 Posts: 14 | hello I cant rememberwhat lengths went where but I did get the torque specs from www.inliners.org under the heading tech tips then under the (Inline Head Torque) catagory hope this helps someone else should chim in about the length placment | | |
#51052 10/11/2005 5:41 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Torque specs for the 216 will work for the 235. Can't recall which bolts go in what hole, but ou can figure it out by how deep the counterbore is in the head. Put the short bolts in the deepest bores.
Fred 52 3600 69 C-10
#51053 10/13/2005 2:55 PM | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I agree with Fred. I don't think you can mix the bolts up. I just finished rebuilding a 235, and I found that the bolts won't work unless you put them in the proper place. The shop manual I have covers 1950 through 1952 and it calls for the head bolts to be torqued between 70 and 80 pounds. Allen | | |
