3 members (BC59, Brian Moore, rfs56trk), 161 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
#51050 10/11/2005 1:54 AM
Custom Title
Custom Title
I'm about ready to put my 235 back together and I notice there are 2 different length head bolts. Does anyone know the proper placement of the head bolts. I'd rather not do it by trial and error. Also, what do they get torqued to? My manual doesn't cover 235's, only 216's. Thanks
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
#51051 10/11/2005 3:59 AM
Junior Member
Junior Member
hello I cant rememberwhat lengths went where but I did get the torque specs from www.inliners.org under the heading tech tips then under the (Inline Head Torque) catagory hope this helps someone else should chim in about the length placment
#51052 10/11/2005 5:41 AM
Torque specs for the 216 will work for the 235. Can't recall which bolts go in what hole, but ou can figure it out by how deep the counterbore is in the head. Put the short bolts in the deepest bores.
Fred
52 3600
69 C-10
#51053 10/13/2005 2:55 PM
I agree with Fred. I don't think you can mix the bolts up. I just finished rebuilding a 235, and I found that the bolts won't work unless you put them in the proper place. The shop manual I have covers 1950 through 1952 and it calls for the head bolts to be torqued between 70 and 80 pounds. Allen
