| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51040 10/10/2005 7:02 AM | Joined: Apr 2005 Posts: 36 Junior Member | | Junior Member Joined: Apr 2005 Posts: 36 | Hi Bolters,
I was under my recently acquired '49 5 window today to check and fill my differntial and found a bolt on top of the driver's side axle. It opens to reveal what appears to be a fill hole of some sort. Does anyone know what this is for?
Thanks, Rich :confused: | | |
#51041 10/10/2005 7:15 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | If you can blow air through it, it's a breather to keep heated gear lube from expanding and blowing out the seals. | | |
#51042 10/10/2005 7:22 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I believe it's a vent hole. It allows air to escape when the gears are spining and oil is thrown around. The volumn of air changes. This way there is no pressure on seals. Kind of like our ........never mind. Cecil........ | | |
#51043 10/10/2005 5:04 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The breather needs to be clear, or you will pressurize the differential when the lube gets warm and blow out the seals. It is threaded, 1/4" NPT if I remember. It should come out for cleaning.
Fred 52 3600 69 C-10
#51044 10/10/2005 5:34 PM | Joined: Apr 2005 Posts: 36 Junior Member | | Junior Member Joined: Apr 2005 Posts: 36 | Thanks everyone! Mystery solved. I would never have figured that out on my own. Bolters are the Best!
Aloha, Rich | | |
