0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 61 | I know know bunches more about switching from generator (12 volt) to Alternator. Mostly from info here. Two question: First I can't seem sto locate the 3 wire alternator. I've seen which alternator to ask for at the parts shop, but can't find it again. Second, I can't get a response from MAD enterprises. Any Ideas? Thanks Bill S. Tempe, AZ I've survived another Phoenix area winter. Windchill 65 degrees.
Bill S. Tempe, AZ
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Go to your FLAPS and ask for an alternator and plug for a 1979 C-10 V-8 pickup. Follow the many wireing diagrams found on this site (white wire on plug is your ignition, red on plug is jumped over to output lead like Oldsmobile did it ), Diode from Radio Shack in ignition line if needed.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill S, There is a page on the MAD site that lists Delco alternator numbers, their 'clock' position and what vehicles they were used on. This is sometimes the best way to approach the counterman for positive results. I have linked that page for you. http://www.madelectrical.com/electricaltech/delcoremy.shtmlStuart | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | First- - - - - -look for a counter man at the parts store who has at least half a head of gray hair. Ask him if he can read a printed catalog. If nobody in the store meets that description, RUN, do not walk, out the door! Today's wet-behind-the-ears computer terminal operators couldn't find an elephant in a shoebox, much less a part that doesn't jump off the computer screen at them!
Unless you live in a town with both city limit signs on the same post, there's probably a local electrical parts rebuilder somewhere nearby. Someone who can take a pile of parts and build an alternator, or (Gasp!) a generator, can get you set up with exactly what you need, the right way, the first time! Jerry
