0 members (),
171
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | My vehicle is a 1963 Grumman Olson, 292 powered. Through some links here, I have been able to find out it is a 2 ton chassis using a VIN decoder page.
My question is, how do I identify my machine at parts counters so that their computerized catalogs will recognize it?
I have used the Suburban of the same year as ID for engine parts, but I doubt that will work brakes and such! | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I would use the '63 2Ton. Should be able to ID off the rearend tag. | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | '63 2 ton doesnt pop up on their computers.
Perhaps an appropriate Chevy series number will. Does anyone know a common Chevy model that uses a 2 ton chassis with dual rear tires? | | | | | Joined: Aug 2003 Posts: 65 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 65 | If I recall, in 63, Chevrolet didn't have a forward control chassis in the 19,500 Lb. GVWR. They were lighter than that, usually a P30 series. The VIN would have a 3 in the model designation. They also were sometimes identified as Dubl Duty in the parts catalogues. Let us see the VIN and we might be able to help.
51 Chevrolet Canopy Express 02 K25 Duramax Crew Cab
| | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | The VIN is 3P362F127XXX What I have found is 2ton, chassis only, built in Flint MI. on a VIN decoder linked somewhere from this great site{!} | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | | | |
