9 members (Mike B, Gdads51, Sjm, TooMany2count, 52Carl, greenie-reddy, 78buckshot, Wayne67vert, Wally / Montana),
98
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,262 Posts1,058,331 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I have a rebuild 235 out of a 1955. I have it in my 57 truck now, but I can't seem to get the shaft from the tranny to go all the way into the motor. :mad: The cheap plastic line up tool I got with the reman clutch & pressure plate seems to go in, but the tranny shaft won't go all the way in.  I have the tranny that came out of my truck (1957 3200)and the tranny I got with the rebuilt motor. I can't get either one to fit all the way in. Anyone have this problem or a guess what it is? Is there more than one size diameter pilot bearing? Could the clutch kit I got from FLAPS be wrong? 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | sounds like your input shaft splines might not be lineing up with your cluch splines
1938 Gmc 1/2 ton
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 3 speed or 4 speed? Sometimes it helps to turn the output shaft a little bit to line it up with the disc. Some shaking may make the difference as well. Usually the rear of the transmission is hanging to far down. This causes the pilot shaft to hit the pilot bearing/bushing. Try lifting the tail of the transmission and pushing it in.
Another trick is to use 1/2 inch 13 thread rod on the top 2 holes. You can then suck the transmission into place with some 1/2 inch 13 nuts. | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Each time that I have put my 4 speed back in, it always hangs up just short of being all the way in. I usually give it a good shove from behind with my feet and in she goes. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it is only 1/2 to 3/4 in. to going in, it is probably not lined up quite right with the plastic tool. Hook up the clutch linkage & have someone step on the clutch while you put bsome pressure on it. If that is the case it will slide right in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Thanks to everyone for the advice. I can't seem to get it right, so I am having a mechanic take a look at it & I'll have him do it so I don't break something. I was going to have him do my brakes anyway, so I'll let him play with the tranny too. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | If you are having that much trouble there may be something wrong with the pilot bushing. It could be dinged up or possibly mfg undersize. Some of these parts are not always made to specs. Fred
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Before you take it to a mechanic, pull the clutch and check to see if the disk slides onto the input shaft correctly. Not likely, but you may have a bad disk or the wrong disk.
Just a thought.
Les | | |
