1 members (Naturalthud),
110
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 26 Apprentice | | Apprentice Joined: Oct 2008 Posts: 26 | i have the 67 rear axle mounted. the parking brake cable mounts to the backing plate different. the one on the 67 axle was cut, so not sure about the other end. a rear brake cable for the 67 is avalaible. will it connect the same way as the orig 54 set up? one option i thought of was to pull the axles and change the backing plate???? anybody been here before??? ccb | | |
