1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Hi all, In 1952, how big of a difference was there between the two models. I understand that a 3100 is a 1/2 ton and 3600 is a 3/4 ton. Is that where the differences stop or is there cosmetic differences Also if you could tell me if my STOVEBOLT is a 3100 or 3600 I would greatly appreciate it. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | You've got a 3600. Cosmetically, the bed and frame are longer than a 3100, with 3 stake pockets per side vs 2 for the 3100. The 3600 (3/4 ton)has 8 lug hubs vs 6 lug for 3100 (1/2 ton). The 3600 is geared lower as well. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 6 bolt wheels and a short bed = 3100 8 bolt wheels and a long bed = 3600
Yours looks like a 3600.
Major differences (besides above items): rear-end ratios, drive-shaft arrangement, frames, springs, brake parts, steering parts, hub caps, running boards, . . more?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just ran the codes for you. It comes up as a '52 3600, built at Flint in October. The engine also comes up as a Flint engines, 3600/3800 application.
Bill Burmeister | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | From the cab on forward the 3600 and the 3100 are basically the same. You'll have different spindles, bearings, and brakes, but basically everything is the same. | | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Wow, Thanks a million guys. I really could of screwed myself ordering all of my parts as a 3100. Thanks again | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If you're planing on upgrading your rear with a late model pumpkin you need to know you frame rails are 11" more narrow than the 3100. That will make a real difference if you want to put a fuel cell in the back or a rear sway bar.
~Jim
