0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 26 | We subframed my 50 1/2ton pickup with a 74 Camaro front end. A jig was built and the new front end was lazer aligned and welded in. Today we dropped the motor in and tried to align it correctly but it was a half inch off of center.. Both motor mounts are the same size those can be ruled out. We noticed there is a bolt hole in the bottom of the saddle under the motor that is perfectly centered. That leads me to believe the clip was made with an offset motor in that Camaro for some reason. Has anyone else run into this problem and how did you fix it? Thanks
'50 Chevy truck 1/2 ton
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Shift the transmission mount half an inch off center in the same direction. Its not a big deal as long as its parallel to the center.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 53 | It wasn't uncommon for the motors to be offset to allow room for steering,exhaust, etc. you get the picture. Just line it up like OldSub said and go. | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | It wasn't uncommon for the motors to be offset to allow room for steering,exhaust, etc. you get the picture. Just line it up like OldSub said and go. I had to offset my gen III smallblock 3/4 inch for steering clearance. it is not a problem. my 71 corvette is offset almost a full inch. | | |
