1 members (Snowman51),
94
12
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50920 10/07/2005 2:12 PM | Joined: Sep 2004 Posts: 14 Junior Member | | Junior Member Joined: Sep 2004 Posts: 14 | Can someone shoot me the correct point gap/dwell for a 1/2 ton with a 250L?
Thanks, Mike | | |
#50921 10/07/2005 10:09 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mike, This info was in this forum several weeks ago....just did a "search".
'66 Pickemup truck 250c.i.
AC 46-N spark plug @.035 gap
Point Gap: .019 dwell 31-34 degrees
Timing is 6 deg BTDC
Hot idle speed: standard 500 RPM Automatic: 'As low as possible to obtain smooth idle and prevent creep in Drive or harsh shifts.'
Idle speed depends on whether or not you have the A.I.R. (smog pump) system.
Stuart. | | |
#50922 10/08/2005 2:47 PM | Joined: Sep 2004 Posts: 14 Junior Member | | Junior Member Joined: Sep 2004 Posts: 14 | atomarc,
Thanks for the info. I had done a search but did not find that post.
Mike | | |
