2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#50920 10/07/2005 2:12 PM
Junior Member
Junior Member
Can someone shoot me the correct point gap/dwell for a 1/2 ton with a 250L?
Mike
#50921 10/07/2005 10:09 PM
Mike,
This info was in this forum several weeks ago....just did a "search".
'66 Pickemup truck 250c.i.
AC 46-N spark plug @.035 gap
Point Gap: .019 dwell 31-34 degrees
Timing is 6 deg BTDC
Hot idle speed: standard 500 RPM
Automatic: 'As low as possible to obtain smooth idle and prevent creep in Drive or harsh shifts.'
Idle speed depends on whether or not you have the A.I.R. (smog pump) system.
Stuart.
#50922 10/08/2005 2:47 PM
Junior Member
Junior Member
atomarc,
Thanks for the info. I had done a search but did not find that post.
Mike
