6 members (Peggy M, Rusted Nut, klhansen, 3B, tclederman, 1 invisible), 24 guests, and 10 robots.
Topics128,010
Posts1,055,308
Members48,419
#509131 02/22/2009 11:48 PM
in taking off my wheel cylinder, 52 3800 series i have the same part # on all 4 wheel cylinders, all the parts cat and store say i should have different front from rear,the bore is 13/8 on all four, and they have the same brake size thread, the delco # is 5450072 so do i have 4 rears or 4 fronts anyhelp would b appreciated trying
trying #509161 02/23/2009 1:07 AM
I don't know about the larger trucks, but on my 52 1/2 ton the front and back are different. What does the shop manual say? It should be explict in the bore, and length of the cylinders.
Jimmie D #509179 02/23/2009 1:39 AM
3B Online: Content
3 Online: Content
Hy trying, Napa numbers. fronts UP4358-$85.99, rears UP9325-$114.00, they both have 1 3/8" bores and are the same from 46 - 52, hope that helps
3B #509211 02/23/2009 2:36 AM
trying,
I believe you've posted the casting number, (not the part number)
which which happens to be the same for the front and rear.
5451615 is the Chevrolet part number for the rear.
5450071 is the Chevrolet part number for the front.
The difference probably being in the adjusters.
I don't think the original part numbers would be of much use now unless you were verifying NOS parts.
Steve
'49 3800
'52 3600
'57 3100
steve you r right it must be the adjusters if mine r ok could i not buy 4 fronts as would be cheaper?thanks for everyones input trying
trying #509296 02/23/2009 5:18 AM
On the larger trucks the adjusters are different styles on the front and back axles - so you can't use fronts on the back - Sorry . Be Sure before you buy. ED H
DaOzTinman #509352 02/23/2009 12:35 PM
Fronts and rears do have different adjusters on the Huck style brakes. The rears mate with an ajuster wheel and the fronts are adjusted with a tool through a slot in the backing plate.
1951 1 Ton Completed
