8 members (Woodcmiami, Hotrod Lincoln, klhansen, DadsFirstPickup, Otto Skorzeny, MickeyP, Wayne67vert, 1 invisible),
50
Mod | | | Forums66 Topics128,043 Posts1,055,605 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50896 10/06/2005 6:57 AM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Hello Bolters, Can one of you T-5 guys tell me what vehicles the T-5 comes in? Also wich one will work the best behind a 235 as far as gear ratios, I got a saginaw 2 groove but the more i hear about the T-5 the more i like it,plus when my local pick-n-pull has a clearence sale trannys go for 69.00 might as well get one then i can choose between the sag.or the T-5, still pluggin away on the 53. Thanks Aaron | | |
#50897 10/06/2005 3:06 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | (jeep mustang) chevy related: astro vans ,s-10' and 15, camaros, firebirds
i had one made using camaro guts in an s-10 housing
go to inliners international, tech, t5
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#50899 10/07/2005 7:52 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Somewhere online I found a list of all the T-5's by serial number that showed the different gear ratios.
Basically, the T-5 came in lots of different vehicles- Ford's Chevys and others...
There are two types of T-5, the world class and non-world class. The world class has better bearings and clutch type syncros. The non-world class is a great tranny with brass syncros and old style bearings. Trucks/vans all came with the gear box in the front.
The differences between the different model T-5s comes down to gear ratios. The camaros etc... had a lower first gear and closer ratios between the gears. The truck/van T-5's had a higher gear ratio in first and perhaps a broader difference in ratios between gears, for obvious reasons (ie getting moving with a heavy load is easier with a higher gear ratio, though it is slower).
The main box/case of the T-5's are all the same but the removable/exchangable tail shaft comes with the gear shifter box in the front, near the main box, or in the rear, at the end of the tail shaft. The best one for the truck, if you are going to keep your bench seat, is the one with the gear box at the front which makes the shifter come through the floor about 6 inches closer to the seat from the original location. Those came in trucks/vans. The ones with the box in the rear came in camaros etc...
Another difference to keep an eye on is whether the tranny is set up for a mechanical spedometer or electronic speedometer. If you want to keep your original guages, you need a mechanical speedo set up or plan on spending $$ to convert the electronic to mechanical.
Another difference is the amount of torque the tranny is designed to sustain. Obviously the T-5's built for v-8s can take more than those for the L-4s. The popular ones for this truck are behind at least a v-6.
The chevy t-5 bolts right up to the original bellhousing from the truck if you just make the bolt holes a bit bigger. The input shaft is the same length within a 1/2 inch, so you might have to file/grind/cut a bit of the tip to make it shorter, no big deal. The input shaft housing may be about 1 inch too long, again no big deal to cut it down.
The last thing is the number of splines on the input shaft on the T-5 is different from the original tranny. So, you'll need the right diameter clutch disc to use it. The tranny I got had the right diameter clutch disc so I used it.
All the t-5's have a model number that begins with 1352 and is followed by a few numbers that indicate which factory configuration of gears it came with. For example, 1352-15 is an early on from a firebird. The one I used was 1352-145 from a 1985 s-10, which has both a nice first gear ratio and a fairly low overdrive.
Some people get a world class tranny and non-world class tranny with the gear box in the front of the tail shaft to put onto the world-class tranny. Other's go to a transmission house and have one built with the gear ratios they want.
Best of luck!
#50900 10/07/2005 8:43 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Here's a couple of pages to help identify a T5. T5 page T5 page | | |
#50901 10/08/2005 1:13 AM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Thanks Guys, I am thinking I will find a S-10 and maybe use the whole setup tranny-driveline-rearend.What do you all think? All behind a 235, someone had pictures of a T-5 in a A.D.if that person happens to see this would you let me know where to find them? Thanks For the help and info. Aaron  | | |
#50902 10/08/2005 3:30 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Here\'s a shot of my T5. It's got the V8 gears and the fine splined input shaft. I also welded an old 4 speed stick to the T5 shifter to get that original look. I think you will find that the S-10 rear end is a little narrow. Don't know for sure. I put a rear out of a 65 1/2 Ton in mine. It's all 6 lug just cause I had nice wheels already. Lemme know if ya need more info. | | |
#50903 10/08/2005 4:16 AM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Shipwright, What gears are you running in the tranny and the rear end? How does that pretty truck do on the freeway?also what kind of mpg are you getting? I would also prefer to stick to a 6 lug pattern but when this truck is finnished It will see a lot of pavement so I am looking to set her up to get around 20mpg if possible.Thanks for the photo I think that is the one I remember seeing. Aaron | | |
#50904 10/08/2005 4:40 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Not exactly sure of the tranny gears. I just told the guy to build me a V8 camaro T5 tranny with an S-10 tailshaft and a mechanical speedo. The rear end I'm running is a 3.73 from a 65 truck. It happened to be the right width @ 62" from wheel back to wheel back. I recently drove from Denver to Kansas City (1200 miles round trip). I averaged about 18 mpg @ 70mph & 2000 rpm. Ran like a dream. Just a little bouncy with the monoleaf front springs. I think I need a set of shocks that match the springs.  | | |
