Hey guys, I'm re-doing my doors and will replace the window channels soon. My 37 has a moulded rubber strip on the door tops that the top of the window rests in when rolled up. I can't seem to find this, and all thats listed is the window channel itself.
Does anyone know where to find this rubber?
Another question, on the bottom glass track(holds the glass) are the two rollers for the wind up supposed to have some sort of plastic on the rollers or, are they metal to metal?
Where can I find some decent door hinge pins? The ones I got from JC are .005" under the size of my 70 yr old worn ones! They wobble in the holes worse than the old ones. What a waste!
Thanks for any help....Jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
