| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Replaced some brake components in my 53 3100 (ss lines, master cylinder, wheel cylinders, etc.) Parking brake pedal does not stay depressed, replaced rubber grommet under dash, still no go. What am I missing? Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | pump truck paul, I have enclosed a nice picture of the parking brake. The little item called the 'brake lock' has to have rather sharp edges where the pedal arm passes through it. These sharp edges bite into the arm and hold it, which holds the parking brake ON! See if the picture helps and take a look at the condition of this 'brake lock'. Good luck. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0506.htmStuart | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I am not disagreeing with Stuart exactly. It helps if the hole in the pedal lock is still mostly round, and the edges are clean. I think this is what Stuart ment. If not please feel free to correct me. Also this whole assembly needs the correct tension to work properly. Even after adjusting everything on my 52 I had to tweak the pedal lock just a bit to get it to work like a champ. As a note while not shown in the drawing there should a small spring between the lock bar and the floorboard that rides on the lock shaft. | | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Thanks. I'll disassemble parking brake,clean it up real good and see if I can figure it out. | | |
