11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible),
72
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Anybody heard of Lockheed type brakes? I first thought of an aircraft type disc brake design but I think it is drum. I ran across this car while doing diesel conversion research. The man says he converted the original Bendix brakes. Any clues? I may email this man and ask him about it.
Professional Novice
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Lockheed [now Wagner-Lockheed I think] made/makes brakes similar to Bendix, but mostly have been used on "other" brands, including many UK/Euro types .... manual ... that's an interesting rig, musta been fun  Bill | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Lockheed brakes were used on Ford cars & trucks from the mid-1930's or before until 1948. Chrysler Corp. cars used them until sometime in the mid-50's. They had two equal-length shoes, and two hex nut adjusters in the backing plates, attached to a snail shell-shaped adjuusting cam. Each brake shoe gets adjusted individually, like a Huck brake. Most Lockheed brakes are not servo type brakes like Bendix, but some of them had a limited amount of self-centering ability from a slotted anchor pin at the bottom of each shoe. Some of the Chrysler Corp. brakes had different-sized wheel cylinder bores for the front and rear shoes at each wheel. Bendix-type brakes usually have better stopping ability than Lockheed, due to the servo action of the Bendix design. Jerry
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You nailed her Jerry! Denny G
Denny G Sandwich, IL
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Thanks! The car does remind me of some of the Cuban cars I've seen pictures of.
Professional Novice
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | my '53 hudson has wagner/lockheed wheel cyls. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | | | | Joined: Feb 2007 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 14 | i know im a little off topic, but THAT IS AN AWESOME CAR!!! 40+ mpg and he could drive 70 mph?!? i want it!!! the only small diesel i knew of that could work in a car was the ford ranger deisel or vw diesel. everything else just seems either too big, too heavy, or they are just too hard to find. too cool | | |
