5 members (tclederman, FAST55, Joe H, lumbersawyer, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#506563 02/16/2009 7:27 PM
Anybody heard of Lockheed type brakes? I first thought of an aircraft type disc brake design but I think it is drum. I ran across this car while doing diesel conversion research. The man says he converted the original Bendix brakes. Any clues? I may email this man and ask him about it.
Professional Novice
Lockheed [now Wagner-Lockheed I think] made/makes brakes similar to Bendix, but mostly have been used on "other" brands, including many UK/Euro types .... manual ... that's an interesting rig, musta been fun smile
Lockheed brakes were used on Ford cars & trucks from the mid-1930's or before until 1948. Chrysler Corp. cars used them until sometime in the mid-50's. They had two equal-length shoes, and two hex nut adjusters in the backing plates, attached to a snail shell-shaped adjuusting cam. Each brake shoe gets adjusted individually, like a Huck brake. Most Lockheed brakes are not servo type brakes like Bendix, but some of them had a limited amount of self-centering ability from a slotted anchor pin at the bottom of each shoe. Some of the Chrysler Corp. brakes had different-sized wheel cylinder bores for the front and rear shoes at each wheel. Bendix-type brakes usually have better stopping ability than Lockheed, due to the servo action of the Bendix design.
Looks like a Cuber car
You nailed her Jerry!
Denny G
Denny G
Sandwich, IL
Thanks! The car does remind me of some of the Cuban cars I've seen pictures of.
Professional Novice
my '53 hudson has wagner/lockheed wheel cyls.
Hey Frank here is a pic of a 50 with a diesel I took last year in Havana
http://s65.photobucket.com/albums/h222/ecumsecumguy/?action=view&current=Picture585.jpg
i know im a little off topic, but THAT IS AN AWESOME CAR!!! 40+ mpg and he could drive 70 mph?!? i want it!!! the only small diesel i knew of that could work in a car was the ford ranger deisel or vw diesel. everything else just seems either too big, too heavy, or they are just too hard to find. too cool
