Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Guitplayer), 125 guests, and 0 robots.
Topics128,281
Posts1,058,486
Members48,490
I was planning on replacing the rear axle seals on my '46 1/2 ton. Started looking at the diff though and it looks like I have to take it completely apart to get to the axle seal. Can I get to the axle though the rear cover without disturbing the pinion adjustment or completely pulling the thing apart? Thanks this is my first experience with an old truck that isn't a Model A.
Yes. It's not that hard. You can remove the rear cover on the diff. and remove the "C" clips on the axels and just pull them out. It won't affect your pinion adjustment.
Best get yourself a service manual, it will give you a step by step.
George
