| | | Forums66 Topics128,281 Posts1,058,485 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50595 09/27/2005 3:04 AM | Joined: Sep 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 46 | I was planning on replacing the rear axle seals on my '46 1/2 ton. Started looking at the diff though and it looks like I have to take it completely apart to get to the axle seal. Can I get to the axle though the rear cover without disturbing the pinion adjustment or completely pulling the thing apart? Thanks this is my first experience with an old truck that isn't a Model A. | | |
#50596 09/27/2005 4:14 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Yes. It's not that hard. You can remove the rear cover on the diff. and remove the "C" clips on the axels and just pull them out. It won't affect your pinion adjustment. Best get yourself a service manual, it will give you a step by step. George | | |
