1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#50592 09/27/2005 1:42 AM
Apprentice
Apprentice
I was wondering if 63 front suspension will bolt to a 62 frame. I would like to coil springs up front and get rid of the torsion bar setup my truck currently has.
#50593 09/28/2005 2:51 AM
Y
Y Offline
With a little work, the crossmember from '63 thru '87 will bolt in. '71 or later will have disc brakes. Make sure you get everything from the donor, including tie rod ends, center link, and idler arm.
Everyone has a different opinion, but most think the torsion bar susp. is superior to the coils. It was cheaper to put coils in, thats why GM scrapped the torsion bars. There are other benefits to torsion bars if you were planning to lower your front end in the future.
#50594 09/29/2005 1:08 AM
Z
Z Offline
ask this at www.chevytalk.com.
