3 members (Tiny, 1955 1 Series, Hotrod Lincoln), 137 guests, and 2 robots.
Topics128,162
Posts1,056,935
Members48,458
#505864 02/14/2009 4:23 PM
Can anyone explain how General Motors made the fenders on the stove bolts?
Was it a hefty press that started with a pre-cut/drilled and sized flat piece of steel, and then pressed/bent into shape using a mirror object?
Anyone have photos of the process? Was the steel heated?
46Canopy
46Canopy #505884 02/14/2009 4:48 PM
you might say the stamping presses were "hefty" grin all the sheet metal went from [usually coils of] flat virgin metal to finished part, either in one strike or progressive strikes - fenders
Flxible #505904 02/14/2009 6:01 PM
Wow!
A STAMPING PRESS THAT COMPLETES FIVE FENDERS A MINUTE
This great machine turns out 2,700 fenders per day, one fender at each stroke. So accurate is the operation that the fender requires no further finishing touches, but is ready to be enameled as soon as the pressure of 225 tons is removed."
This is no backyard tool. Great photos. I had no idea.
Thank you Bill
Dale
46Canopy #505947 02/14/2009 9:30 PM
Those aren't AD fenders. I'm sure that AD fenders were done on "progressive dies" which is just another way of saying more than one forming operation. Keep in mind that the dies themselves were all made without the benefit of any computer aided machining... just lots of meticulous hand work.
I worked in Detroit in the 70s and it's nothing short of amazing the skill required to make a simple forming die.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
