2 members (Patharr, 1 invisible), 45 guests, and 3 robots.
Topics128,090
Posts1,056,027
Members48,432
Apprentice
Apprentice
Im looking for a thread that shows how to modify a stock exhause manifold to make it into dual exhaust. I tried the search function but dont even know where to begin.
Rust Lover
Here's a good one.
CLICK
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
curt b does some nice work. i am saving this link. does it matter which side of the manifold you modify? i think this is the first one i have seen modified towards the front of the manifold. all the others i have seen, including gm originals have the second exhaust flange on the rear of the manifold. just wondering??
original
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320329909351&sspagename=STRK%3AMEWAX%3AIT&viewitem=
self modified
http://cgi.ebay.com/ebaymotors/HOT-...torsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
THESE LINKS ARE FOR REFERENCE ONLY!!
big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Thank’s Big Ed. My criteria for a second outlet is to duplicate the stock one as much as possible and front dump leaves the most room for a column shift application. If it’s flanged, studded, beveled, and of equal size I can’t see why it would show anything different from the vette one on a dyno. I need instant driveability with my truck to enjoy it as a daily summer driver so the heat riser system is a must for me especially with a pair of 235 size carbs, a northern climate, lots of altitude, and now an anti-idling bylaw. In fabricating one my best advise is to insure the additional outlet allows for removal/replacement of the weight for welding clearance. I have a rear dump one for a side mount car and maybe a 292 version to do in my near future and will add anything I learn about those.
http://rides.webshots.com/photo/2611187020023244788cCGtIY
I don’t weld these myself. A friend/co- worker with 30+ years of B pressure yearly certification enjoys the distraction of some old school stuff however the right rod and procedure will work for anybody with the patience to do a good fit up. 2” heavy wall gasfitter elbows are common as dirt and there’s no shortage of people with the welding skills so I don’t understand why this isn’t more common. headscratch
http://rides.webshots.com/photo/2161711250023244788PcOIEW
You Tube
