| | | Forums66 Topics128,197 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50568 09/26/2005 7:32 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | In my 1953 GMC the speedometer worked when it was out of the truck, I installed it with a new speedometer cable and it doesn't work. I think it may be the gear in the transmission. Does anyone know how to check this or have a schematic that shows how to replace it? | | |
#50569 09/26/2005 9:42 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Remove the cable from the trans. & put a small screwdriver in the square hole that the cable went in. If you put the rear axle on stands you can run the truck in gear & the screwdriver should go around. Or you can put it in neatral & block one wheel from turning & have someone turn the other rear wheel as you watch to see if the screwdriver turns. If it doesn,t you can remove the driven gear buy the large hex on the retainer or a bolt & clamp holding it in. I,m not shure which one this model uses. If the gear is bad you can replace it with one that has the same number of teeth. If the inner gear is bad you have to partially disasemble the trans.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#50570 10/05/2005 2:10 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | If it's not moving at all, then see if the cable is turning by letting it hang under the dash and then looking at it while moving the truck or rear wheels. If the cable is moving and the speedo is not, that would be unusual.
I've seen many of the heads on the 47/53 speedos fry when the truck is run at highway speeds. It will make noise and then have one last gasp as the cable snaps because the bearing in the back of the speedo head is seized.
Scott's Speedometer in Pontiac, MI has tons NOS parts to repair, rebuild, and properly calibrate these and their work is first rate. | | |
#50571 10/05/2005 3:01 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | howdy Kook! Bill | | |
#50572 10/07/2005 12:12 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Did you check to see if the odometer is working? If it is, then you have a problem with the head. When the bearings in the head get worn, such that there is a lot of clearance in the thrust axis, inward pressure will cause the speedometer to freeze. | | |
