7 members (1955 1 Series, Rudedog53, wilbur53, Oswald, Phak1, Charles in CA, Stewart2),
67
Mod | | | Forums66 Topics128,181 Posts1,057,191 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | OK I got the 261 out today for a little cleanup and paint. So, before painting it I snapped a shot. I think I know what all of these holes are for but, I thought someone could lable them for me and it might be useful later on. Anyone with any suggestions are welcome. oops I just noticed two h's sorry little h and big h. 261 motor Thanks
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | H- a hole for the generator bracket bolt F- those three are for the side engine mounts B&E I think are the oil send and return for a filter h- is the hole for the bellcrank stud D- thats a drain plug for the water jacket
Thats the best I can do, hope it helps!
58' 3200 235 3-speed/OD
| | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | A=port to oil sump-this is used for the bypass style oil filter
B=oil pump output-directly above B port is the pin that you have to drive in to block the internal passage, thus directing all the oil pump's output to this port
C=plug for water jacket-I'm not sure what it is for
D=drain plug for water jacket
E=oil galley inlet port--oil leaving port B goes into a full flow oil filter-the filtered oil leaves the filter and enters the engine's oil galley at this point
F=side motor mount bosses
G=not sure
H=this is where the throttle linkage pivots. A special bolt screws into this hole and allows a stamped steel pivot to transfer movement from the gopedal to the carb. | | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | C is for an alternate throttle pivot, depending on which vehicle you are putting the block into.
I don't think my 261 block has holes drilled in G.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | My two late-model 261 engines(full-flow filter engines) have the two bosses at G, but only one has the bosses drilled and tapped. One of the blocks does not have either the A or C holes. It does not appear that anything had ever been attached to the G holes. My 1954 261 block does not have the G bosses at all. The rest of the holes on my engines are as ApacheFiend and Racecarl described.
Hoyt | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | My 1960 and 1959 261s have both holes G. They were not used but they are threaded. I use those holes to hold a full-flow remote, spin-on oil filter head to the block.
I do not understand Racecarl's reference to a by-pass filter being used with a 58-62 block. If you do not use a full-flow system on 58-62 blocks (and never moved the pin/diverter-plug) does a by-pass filter work on the 58-62 blocks?
| | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Thanks for the info guys. I have labeled the picture, see what ya'll think. Labled 261 | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Tim, I am playing around with mounting my remote filter on my 261. I didn't see a pic on your great site. When you have the time would you post or email a pic of your filter set up? Thanks in advance.
Drew
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Drew, I only have one photo of full-flow, remote-filter-head mounting plate on my 1960 261 (not yet listed on my web site). Tim | | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Tim,
Those pictures are great. I like the location of your remote spin-on filter. Did you fabricate those lines or did you have them done? Also, I don't have the throttle pivot bolt and bell crank, do you know where I might locate one of these? I sure wish I was as dedicated to documentation and Blogging as you are. Sites like yours are like gold to me. Thanks. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The hose and fittings were bought from Summit Racing. I made up the lines (with a little help from my friends) and they are very short. There was not much flexibility in the lines over that short a distance.
Place a Want Ad in the Swap Meet for the pivot bolt and bell crank.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Tim,Thanks! I hadn't thought of just making an offset bracket for the mount. I am temporarily using square tube aluminum over the same two mounting holes to mount the fiter adapter. My engine is still in a cradle as I haven't completed the exhaust system,but when it's ready to be installed I'll check my clearances and see if your idea can work for me.
Drew
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | 1954Chevy5Window, Cory, Check your email. Regards, Steve Sr. | | |
