2 members (J Lucas, Sjm),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,534 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | My old Saginaw 4 is starting to howl a bit, so I'm figuring on biting the bullet and giving it a rebuild.
The rebuild manual is on its way, and I'm going to go through the process and get together the assemblage of everything I need before I start, lock ring pliers, pipes to dislodge seals, etc. It's been sloppin gear oil around pretty profusely, so it needs cleaned.
So here I ask, any sage advice before I get started? There's lots of rebuild kits, and I've been looking especially close at D&L's. Anyone have another kit suggestion? Any tips from past experience? Amusing stories? | | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Here's a start.... I used this company to order manual transmission parts for a '62 3sp+od. With the economy the way it is a call to the several companies you can search on ebay will allow you to obtain the lowest price, all-american bearings, more complete kit, etc. A parts washer would be handy, rebuild manual, tools on hand. I don't know what you mean by, "It's been sloppin gear oil around pretty profusely, so it needs cleaned." That's what happens inside of these old trannies, 90 wt. gets slung around. Do you really need a rebuild? Have you changed out the 90 wt.? I'm using 90 wt. synthetic. Here's another thought. Daily driver = Rebuild The Transmission. Parade or Seasonal Driver ~ several hundred miles a year = New 90 wt. synthetic and spend yer money on wax.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | Thanks for the link. Yeah, that thing about cleaning it, that was just sort of an errant thought I typed out for some reason. Actually I think the seals at either end are probably shot, so the whole outside of the thing is a mess. I've been adding gear oil regularly to keep it happy.
The truck is my daily driver and chief means of travel, so I'm trying to get as prepared for this as possible, pull the thing on a Friday and hopefully having it back in before work Monday. If I get in there and things are a real mess, like I want to replace a gear or something, I can always ride the bus for a while.
I don't have a parts washer, so I'm figuring on getting a buddy to take me down to the carwash with the main case and extension and clean those up that way. | | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | Job completed successfully, fairly straightforward stuff. Anyone interested in trying the same feel free to contact me for advice. | | |
