0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#505244 02/12/2009 7:04 PM
My 3/4 ton has 8 lug wheels. I am on my third set that when mounted they hit what I think is the tie rod behind the wheel. the wheel seems to deep. has anyone run into this? what wheels are to be used as these are 8 lug gm wheens in all cases. can the rod be shortened or so I search for other wheels for the front??
56 stepside 3/4 ton longbed
56 stepside #505273 02/12/2009 9:26 PM
If you are referring to a 1956 truck, and if the wheel offset measurement is what you are looking for, that information is, I think, found on this page.
tclederman #505278 02/12/2009 9:50 PM
Riding in the Passing Lane
I've never done it for that reason but I understand that if you change to the modern replacement tie rod ends they clear.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #505326 02/12/2009 11:40 PM
Apprentice
Apprentice
Im having the same problem with my '50 3/4ton. I want to get rid of the split rims. I tried the spare off my '03 3/4ton and they bolt on the rear fine, but hit the tie rods. I've been told that rims off early '90s dodge 3/4-1 ton vans fit well, and clear the tie rod.
Rust Lover
wesfab #505329 02/12/2009 11:51 PM
Actually, it's the Backspace that is the important measurement. You'll want no more than 3 1/2" of backspace. Offset and Backspace tend to get used interchageably for the same measurement, but that isn't the case. Backspace is the dimension from the edge of the wheel lip to the bakcside of the wheel mounting surface (where it bolts to the hub). Offset is the amount of difference from the mounting surface to the centerline of the wheel. Different width wheels will cause the offset reading to be diferent if the backspace is maintained and vice-versa.
I do know that Dodge truck wheels (pre '93) work alright, and pre-'87 GM wheels should be fine, too. I've also heard that Ford van wheels work with a 3/16" spacer (one of the few times I'll endorse use of spacers).
Bill Burmeister
LONGBOX55 #505339 02/13/2009 12:24 AM
No spacers will fix this? I am not a proponent of spacers either, but this is my third set of rims.
56 stepside #506091 02/15/2009 4:31 AM
Y
Y Offline
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=242163#Post242163
this web address is to a thread on this site with some one piece trailer rims that can be modified to fit the correct hub caps and they look good.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
