| | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 26 Apprentice | | Apprentice Joined: Feb 2009 Posts: 26 | I was considering the idea of changing my wife's truck to automatic transmission. I was wondering, has anyone ever put a powerglide in a pickup? If so, whats a good transmission? Whats a good donor vehicle?
Rust Lover
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what year and size truck? what engine? you sure don't want an actual "powerglide", at least not the original cast iron version, about 1950-60
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What engine in what truck?
During the 60's the Powerglide was used in pickups so GM thought it was an okay idea. I once owned a '66 with a factory 327 and Powerglide and it was a nice driving truck.
There are two basic versions of the Powerglide, the original cast iron case version and the later alloy case type. My '66 was the later one. That later one was never made with the bolt pattern to bolt directly to a Stovebolt six.
The early version came with both the V-8 pattern and the early six pattern. GM never used (far as I know) the early version in pickups, but instead installed the 4-speed Hydra-Matic.
Unless you have a Powerglide I'd encourage thinking in terms of a newer automatic.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2009 Posts: 26 Apprentice | | Apprentice Joined: Feb 2009 Posts: 26 | The truck is a '50 chevy 3600. The engine is a 235. Honestly, i'de be happy with whatever bolts up the easiest. The reason im thinking automatic is because she cant drive stick.
Rust Lover
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Why not use a 50-55-1st Powerglide in a truck? Perhaps because the enclosed driveshaft length (and spring mounts) would not work? Or, is there something else inherently incompatible?
| | | | | Joined: Feb 2009 Posts: 26 Apprentice | | Apprentice Joined: Feb 2009 Posts: 26 | its a 3/4 longbox, it has a two piece driveshaft. Honestly i cant remember if its a torque tube going to a prop shaft, or if its two normal prop shafts. No matter what the case is, its not hard for me to make a driveshaft that will work.
My main concern is finding a tranny that will just bolt up to the 235, i dont want to spend $$$ on adapters. We wont be using the truck for heavy work, so im not worried about the tranny being able to handle heavy loads. Eventually, i would like to swap out the rear end for something with road gears. right now its running 5:something gears with the stock 4spd. I had a heck of a time gettin her up to 30mph. Poor ol' gal cant seem to get out of her own way. Could be because she hasnt run for 20sum years before i brought her home.
Rust Lover
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Unless it's been changed it will have a torque-tube front half of the driveshaft - back to the carrier bearing, with an open shaft back to the diff. And the 50-54 cars with Powerglide had torque-tubes. The only automatics that will bolt direct to your 235 are the 62 and earlier cast-iron PG and the early truck Hydramatic. I think another guy who has posted on here has done the PG swap. Try a search of these forums. Good luck with this and keep us posted.
Professional Novice
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 5.14 rear gears were an option with 4.57 being standard in a 3/4-ton. You might find a 4.11 gear set from a later truck with the Eaton rear that would swap right in.
I think when you compare the cost of rebuilding a cast iron Powerglide or a Hydra-Matic (the only autos that could simply bolt up--you have to get the right version of each) to the cost of an adapter and something like a TH350 you might find the adapter is not all that expensive. Maybe you'll find a good one cheap, but its hard to bet on.
I'm concerned about the condition of your motor. If you have trouble pulling past 30 mph you may have more problems than just a transmission will solve. Even with the 5.14 gears 45 or more should be possible with a healthy motor and stock size tires.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2009 Posts: 26 Apprentice | | Apprentice Joined: Feb 2009 Posts: 26 | poor truck hasnt run in over 20 years. It still needs the cobwebs spit out of her.
Rust Lover
