| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Anybody use Picklex 20? Sounds like an easy to use product for anybody not doing a frame off, but wanting an easy application for treating rust and making a sound surface for priming/painting.
This truck will be a daily driver, but while I am replacing some of the floor pan, I would like to treat and paint some of the exposed frame parts. I have used a wire wheel except in the really tight spaces where I can't reach. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | That product is for treating bare metal. Unless you plan to strip your frame down that's not what you want.
Just use what is tried and proven to work... POR15 or (my favorite) Rust Encapsulator from Eastwood. Both are effective and reliable ways of getting a base coat over any rust. | | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Picklex is for bare metal, Picklex 20 is listed and shows a spec sheet for rusted metal.Just hoping to find someone who might have tried it. I have tried POR 15, too expensive for the mess and toxicity. I might give the Rust Encapsulator a try.
Thanks! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Rust Encapsulator has several advantages over POR 15. It's not as expensive, it's lacquer based which means clean up is a snap and you can thin it and spary it and just keep what you don't use for another time. HERE is an interesting side-by-side comparison of the two products. There are people here who swear by both products. | | |
