| | | Forums66 Topics128,035 Posts1,055,556 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Anyone have a good suggestion on uncovering the hand painted company advertising on the side of my truck? What has happened is I can see the patina, but it appears that someone has hand painted over it, to cover the lettering. I tried scotch brite, but it started to remove the lettering.
I think it would be cool if I could restore the slogan on the side, and leave the original paint unscathed if possible.
Any suggestions?
Thanks | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Don't know if it would work, but your best bet might be to wet sand with 1500 or 2000 grit sandpaper. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | You might try a thin layer of diluted paint stripper. Often times paint stripper will only remove one layer at a time... test on a small area.
You might also try lacquer thinner. Sign paint is enamel and old trucks were painted with enamel and lacquer thinner has much less effect on enamel. You may have lucked out and the top coat could be lacquer which could be stripped off quite easily without having much effect on the paint underneath it.
Sandpaper or any other abrasive is just going to cut whatever it comes in contact with.
If it were me, and none of my suggestions worked, I'd go at it with the sandpaper until I could see it well enough to make a tracing and then find an old-school sign painter to re-create it.
Regardless, I'm always looking for vintage door art and would appreciate a photo for the collection linked to below. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Good luck but I don't think you'll have any. I faced a similar issue with my data plate the the PO had rattle can painted over. I've found no way to remove just the rattle can paint and leave the factory paint. I ended up having to buy a repop data plate which obviously you can't do.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I've heard that oven cleaner will work. I've used rubbing compound myself and had decent results, just take your time and don't over do it. | | | | | Joined: Sep 2008 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 105 | I don't know if this would work for your application or not but I had my '99 S-10 vandalized with spray paint on the tail gate. I used nail polish remover on a soft cloth. Rubbed it on very gently and it got the spray paint off but didn't do anything to the finish. I then washed the entire area with soap and water to get any residue off.
Good luck! | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | oven cleaner will take all the paint off
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | i build alot of model kits and if you have a way to get a lot of it and can soak the parts brake fluid takes paint off right down to the base metal/plastic
1937 1/2 ton
| | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | I had a similar situation to the one Tiny described with the painted over data plate. I was pretty lucky, a citrus based paint stripper took off the top paint layer and left the data plate looking great. I also took Woody's advice and tested it on another area first. | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Ok,
Well I will print the suggestions and hit the medicine cabinet for the nail polish, (hope she won’t notice its missing) then head to the hardware store for the other supplies. I am optimistic that one of the ideas will work. If successful, I will post photos of the results. I would post photos now, but the camera just won’t pick it up.
Results forthcoming.
46Canopy
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Nail polish remover is acetone with some moisturizer added. If you want to be able to apply fresh paint without having fisheye problems use straight acetone from the hardware store. It dissolves lacquer paint pretty well.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2000 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 38 | I'd try the very fine wet sandpaper method. Bought a motorcycle one time with a black gas tank, started sanding it down to re-paint and discovered a very nice blue paint job with flames underneath. Sanded very carefully with fine wet paper, turned out nice. Good luck. | | |
