2 members (J Lucas, Erniegp), 78 guests, and 2 robots.
Topics128,054
Posts1,055,780
#505062 02/12/2009 4:06 AM
A few AM transmitters to get my Ipod into my radio.
This one is not tunable but cheap. It may need a regulator to bump 12 volts down to 9.
http://sci-toys.com/scitoys/scitoys/radio/am_transmitter.html
This is a kit that is tunable.
http://www.hobbytron.net/R-AM-1.html
Any thoughts.
I've tried a half dozen AM xmitters, built all except one and best one out of all of them was the "Radio DJ" kids toy transmitter with a built in cassette tape player. They used to sell them at Toys-R-Us but I haven't seen them in years. The next best was an SStran AM transmitter kit, ran about $100 and u-build it. The others were hobby kits like the one your looking at, a couple of scratch built, a couple of kits from AES and all were very erratic and almost impossible to tune. And that sitting on the bench in the house not bouncing around in a truck cab and with 1w output to boot.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks for the input Denny. I am looking for something that I could mount under the dash next to the radio. I may try to pad down the output of the first transmitter to a few micro volts and use an antenna switch to put it straight into the antenna input. The other option would be to modify the radio with a switch to go between the detector output and the Ipod output through a capacitor.
Now Neil ya see, that's why us northerners seem so aggressive, ya gotta pay better attention!!!!! Just pullin your jeber thar Neil. But I did post a thread back a couple of months ago announcing an item that deals directly with this.
Take a look at http://www.rediscoveradio.com/NewVers_ZenCart/ I bought one of the new 6v versions. That will allow your to play your stock radio like normal from the standard antenna or you can take a signal from any output like a walkman, iPod, pocket FM, satellite radio, that is, anything with an earphone jack and play it through the stock radio. It directly transmits a signal on one of the higher less used frequencies.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
That looks like the ticket. I had seen that but couldn't remember where. Thanks.
Moderated by  truckernix
