1 members (ndkid275),
115
Mod | | | Forums66 Topics128,261 Posts1,058,344 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | What is a rear bumper bracket gravel shield? I am looking at the truck shop catalog for 1960 truck.Pg 129.Just put on a bumper(never had one) it looks like it's missing something. | | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | The gravel shield on the front bumper on the older models is the piece that goes between the bumper and the grill. I have never heard of a gravel shield on the rear, but I guess one could be fabricated to fill the void between the bumper and the box. | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | For some of us. We will put a "Mud FLAP" just before the rear bumper between the rear wheel and bumper.
This could be a protector of that era. as it would prevent rocks from hitting your bumper?
??? Someone here may have a truck of that age and can compare.
Good luck Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There's one being marketed for ADs but there never was one from the factory. I suppose they could be making one for the 60s models too. I don't know if they had one originally or not but I doubt it. | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | On 1960 thru 1966 some models came with a piece of plastized rubber like material to keep the mud and rocks from chipping the paint on the bumper. It was a special order part. My Dads 1962 had it. It kept most of the dust,dirt or mud, gravel from hitting the bumper tailgate area. After becoming brittle it cracked and broke out so dad took the rest of it off. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Can you give us a link? '50s GM cars had a rubber flap that ran the width of the vehicle, between the tail panel and the bumper. It kept dust and grime from getting up between the bumper and the panel. There was a U-channel stamped into the panels, and the bottom of the back of the quarter panels, the rubber went into it from the top, and the channel was crimped closed/pinched with a hammer to hold the rubber in place.
My '62 Suburban has a similar rubber seal, though it uses a sheetmetal strip that screws to the tail panel, sandwiching the gasket between it and the body.
Installed, the rubber goes toward the sky, and is folded over to tuck up behind the bumper. It doesn't just hang down.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | |
