| | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | I have read that POR15 and Corroless are good at reacting chemically with rust to form a stable magnetite. They are said to stop corrosion and protect the metal against moisture. Unlike POR15 which can deteriorate when exposed to UV light, Corroless does not need to be recoated---either with a primer or a finish paint. However, the Corroless is said to be compatible with most auto. paints and can be top coated if desired. I plan on having most of the body work hired out but wanted to do my frame myself. However frame may be exposed to light for months before body added. SO----which should I use POR15 or Corroless? Thanking everyone in Advance---Design, that is. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | How about POR 15, top coated with Hardnose paint. hardnose and POR 15 are made by the same company. That would be very durable combo... check out their website. Google POR 15 | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | One other thing- not sure if you're wanting gloss or low gloss paint. I should have mentioned that the hardnose paint only comes in gloss. Eastwood has some coatings that are supposed to be good- chassis paint with ceramic. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Yup trucknut, I been readin Eastwoods claims on there NEW ceramic impregnated chassis paint and its UV protectant ..wonder how it werks ???...HEY Funton maybe you can check it out an give us all a report ?? you can be teh StoveBolt Guinnee pig ..lol Tim | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | SW, I just ordered a quart of the chassis paint for my running boards. It should be here Friday, and hopefully I'll have it sprayed that afternoon. I'll let y'all know. I'm going to be spraying it over K38 primer, btw.
| | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I used Corroles on my frame and am very pleased with it. I topcoated it with Eastwoods Chassis Black. Some of the chassis parts sat outside through Florida's rains, and still looked great when I got ready to topcoat them. I haven't had any problems with rust appearing. Samantha | | |
