4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#50469 09/23/2005 5:08 AM
Moderator
Moderator
I have a carb to play with. It's a Holley 4360 Economaster (L-7455 stamped on air horn). Trouble is, it's been 20 years since I have had a carb apart. I got a book on Holley carbs from the library and it seems like it covers all but this one. The instructions with the rebuild kit (Holley #37-1540) are pretty poor.
Does anybody have a better set of detailed instructions? I've learned a lot of general things from the Holley book, but it would sure be nice to have a decent exploded diagram and some better instructions.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
Moderator
Moderator
I got the air horn off, cleaned up and reassembled with new parts today. Tomorrow, time permitting, I will work on the venturi body. I split it from the throttle body before knocking off. I figure if I concentrate on one section at a time I may squeak by with the poor instructions I have.
Burma-Shave (1947)
Moderator
Moderator
I keep hoping someone will come along with a good set of instructions or at least an exploded parts diagram with labels. I couldn't get back to it until tonight, but I got the venturi body cleaned up and partially reassembled. Hopefully tomorrow night I'll get this section reassembled and mated back to the air horn. Then see when I can get another evening to finish it up.
Right now I have a little carb cleaner buzz...
Burma-Shave (1947)
