0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#504579 02/11/2009 3:03 AM
Apprentice
Apprentice
I need to replace the kingpins on my wife's '50 3600. I have never done this before. Any info would be greatly appreciated. I can buy a kit right? Or do i have to buy each piece individually?
Rust Lover
here is a link to the tech article on this site.
http://www.stovebolt.com/techtips/kingpins.htm
and there are a few places that sell them.
classicparts.com, brothers trucks, lmc trucks are a few.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Apprentice
Apprentice
Thanks for that. Im going to print that up, grab a sixer of PBR, and go to town. Great tech artical.
Rust Lover
anytime...
i use to alway forget they have the tech section here.
leonard
I think that there are some details that are either missing or differeent from the tech article.
The end plugs on the spindles will not have locking rings or clips. They will have what looks like small frost plugs and they are removed with a punch. The new ones will need to be treated to a few blows in the centre to lock them in place, just like a frost plug.
I didn't see any details on replacing the kingpin bushings. If yours are the pressed in type, which I think they are, the old bushing need to be pressed out and new ones installed. Then the new bushings will have to be reamed to fit the kingpins.
You have to measure and adjust the verticle play in the spindle/axel assembly. Shims are provided in the kit for this purpose.
1951 1 Ton Completed
I did the front end on my 3600 last year. Pulled the axle, separated the spindles from the axles, drifted out the bushings and cleaned everything. Then let discretion be the better part of valour and took the axle and all parts to a truck suspension place here in Calgay. They pressed and reamed the bushings and reassembled everything with their big tools. Happy to pay that bill for what holds up the front of my truck.
