| | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | Dad and I were all set to order a Superride II from Heidts until they told us that it would be a 2-3" drop bellow factory ride hight.
Dad really wants a nice ride but factory ride hight, ie NOT a low rider. This is going to be a daily driver that looks some what original but rides better than new.
Should we be looking at other Mustang II / 4 Link companies like TCI in order to stay clear of the speedbumps and closer to factory ride hight?
Is it crazy to think about adding 2" or 3"'s of hight back by say 2"x2"x 1/4" square tubing between the bottom of the frame rail where the Superride would go in order to keep it out of the weeds? Has that been done before?
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Is that with or without dropped spindles? What size tires/wheels are planning on useing? If your going for stock ride height you'll have to stay with stock suspension, most all of the IFS are designed to lower the truck. A 2-3" drop will not put you down in the weeds. | | | | | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | They said 2-3" drop from stock ride hight WITHOUT the 2" drop spindles. Sorry I should have said that, I did ask the tech specifically about that. He did say the 4 link had 4 different mount holes so there was some adjustability in the rear. Yakima, wow your close to home  Thanks
