4 members (Hotrod Lincoln, FishinToms53, Bill Hanlon, Charles in CA), 71 guests, and 3 robots.
Topics128,087
Posts1,056,000
Members48,430
#503893 02/09/2009 7:05 PM
1 Offline
Pulled my SM420 out of my 51 3100 just to go through it. Shifting seems smooth and no known issues when I drove it including no leaking. I took the cover off and it looks pristine in there and well maintained. Having it out I notice that the input shaft wiggles a bit. Question is should I put in new bearings or just put new gaskets on and seal it back up leaving well enough alone?
1951 Chevy 3100 5 window with a 1958-60 235 and original 4 speed.
Purney,
If it didn't howl, I would leave it alone. That ball bearing has to have clearance to operate, and when you vector (?) that to the end of the long input shaft, it will probably show up as a small amount of wiggle.
If you are still unsure, price the bearing and compare it to the amount of labor and mashed knuckles it took to remove the tranny...if the bearing price is cheaper than the peace of mind, stick a new one in.
That's my two cent take on the situation! smile
Stuart
1 Offline
Thanks Stuart. Tranny didnt howl, if the slight wiggle is normal then I think I will leave well enough alone. New gaskets and off I go!
Riding in the Passing Lane
Stuart is right. While you have the front retainer off take a bright light & shine it in the front bearing. Turn it slow & check for any pits or roughness in the races or balls. That is the part that wears the soonest & can cause the most noise. It can be replaced without tearing down the trans.
1972 Chevy c10 Cheyenne Super
1 Offline
Will do, thanks Wrench.
Thanks Wrench. I have mine on an engine stand. I will check that before I put it in the truck.
Dennis
That transmission is a rock crusher. In production for 30 years seeing duty in heavy trucks, busses and military vehicles.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Check the pilot bearing.
'67 GMC 3/4 292 4spd
