7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Just put in a new (rebuilt) power steering unit in my former manual steering '62 c-10. The kit came with a rebuilt steering box and pump from a '68 thru '76 truck. Everything runs OK, but it makes lots of noise, sort of like when you turn the wheel on a power steering on a car all the way in one direction and hold it there. The noise is only when you turn the wheel, even slightly, then it really squeals. The belt is not slipping. Questions: 1. Anyone had this happen before 2. I think only the pump could make this noise, correct ? 3. Any suggestions. Thanks in advance. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | sounds like air in the lines,might need bleeding,just a guess. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That sounds like a belt slipping to me. Maybe something is causing too much pressure. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | sounds like you are sucking air and cavitating the pump. Check your fluid level. If you did not bleed it prior to checking fluid, when you turned the wheel, it moved the servo off center and started filling the rest of the sytem. If that is the case, then you simply need to add more fluid. however you could have a bad pump as well.
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | It is not a belt slipping, or belt misalignment. But....I did not bleed it before I filled the pump, since I did not think I had to since it has a low pressure return line to the pump. OK - I screwed up, but the pump is filled all the way (I overfilled thinking that it was a low fluid problem). How do I bleed this thing now ? Can I just drive it and it will eventually work the air out itself ? It makes no noise when you are not turning the wheel in one direction or the other. Thanks for the responses. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The recommended way to bleed the systen is to jack up the vehicle with both wheels off of the ground. With the engine shut off, turn the wheel lock to lock about 20 or more times. Check the fluid and fill then start it up and check the operation. It should be OK. Fred
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | or simply turn the wheel to one with the engine running, then turn back. you need the pump running properly to bleed it. If the noise stopped, then you have the air out.
BTW, the fastest way to kill a PS pump is to run it low on fluid. Cavitation kills.
