11 members (klhansen, cmayna, Hotrod Lincoln, Peggy M, Wayne67vert, 52Carl, Forty9, walter74, HandyAndy, 2 invisible),
142
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50239 09/16/2005 7:37 PM | Joined: Feb 2005 Posts: 8 Junior Member | | Junior Member Joined: Feb 2005 Posts: 8 | i want to update my strait axel to disk brakes on my 51 1 ton. does anyone know if the spindle size on a 1ton is different than a 1/2 ton? | | |
#50240 09/16/2005 8:02 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | No, you can't use the 1/2 ton kits. Do a search on this site for disc brakes, this problem and it's solutions are discussed in several other threads. Try this for how I converted my 52 1 ton http://www.stovebolt.com/gallery/mullen_grigg_1952.htm I will be glad to answer any questions you may have. Or you could find spindles with disc brakes you like and adapt them to your original axle, I think someone in texas has done this with Dodge parts? But as far as I know, nothing is just bolt on for the 1 ton disc conversion. Grigg | | |
#50241 09/16/2005 8:43 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Grigg, is it possible for you to post more pictures of the work you did on the front axle swap? I you don't have a place to post, I can do it for you.
Fred 52 3600 69 C-10
#50242 09/17/2005 6:45 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Yo Jkastner51 - I have a 59 which I am pretty positive uses the same brakes. Look at www.praisedynobrakes.com I got kevlar linings from them and my brakes work really well. If you are not looking to just upgrade the brakes, like lowering the suspension, etc, then that won't work for you. I have had 3000 lbs in scrap iron on my truck and the brakes work fine. I also have a new power brake 7.5 inch booster on a 61 corvette master. | | |
#50243 09/18/2005 6:32 AM | Joined: Feb 2005 Posts: 8 Junior Member | | Junior Member Joined: Feb 2005 Posts: 8 | Thanks guys for all your help, im still not sure what i want to do yet, maybe a whole ifs, i got some stuff to look up still. | | |
#50244 09/19/2005 10:30 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | How do you intend to use this truck? Maybe that should have been the first question. Most the IFS solutions are geared to hot rodders, not working trucks.
My guess is that the best IFS for a real truck would be one from a 1-ton pickup. The Mustang II, Pacer or Camaro clip approaches aren't going to have the load capacity or brake capacity a real truck needs.
If hot rod is what you are building, and you're not going to haul a load, another approach might be to find a front axle from a 1/2-ton, adapt that to the front of your 1-ton and then use a disk brake kit.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
