3 members (Otto Skorzeny, Hanks custodian, Guitplayer), 191 guests, and 4 robots.
Topics128,187
Posts1,057,313
Members48,468
#5021 10/24/2003 3:47 AM
ok its been 16 months and i cant remember where a line goes. 1958 235 on the right side of the head just above the number 3 and 4 spark plug there is a fitting. is there a line that goes from there to where the oil is pumped (other side of engine) to the oil filter? I have a place to hook 3 lines there, oil filter, oil pressure, and ???.
#5022 10/24/2003 4:15 AM
On my '58 235 the oil filter holes are both on the drivers side. Maybe someone drilled the other side for a pressure sender.
Here's a pic of my motor where you can see the oil lines Photo here
#5023 10/24/2003 9:23 AM
52GMC,,,, is your engine a 235 (Chevy) or a 228, 248, (GMC)??
#5024 10/24/2003 1:39 PM
On GMC engines, from the port under the distributor plum to bottom center of filter assembly. From side of filter assembly, plumb to "T" junction block in port on lower left front of block next to timing cover. From other side of "T" junction block in port on lower left of timing cover plumb up to port in head on right side of thermostat housing. See photos below of 53 4 me's engine I took a couple of years ago for exactly this reason.
[img]http://www.oldgmctrucks.com/photos/stovebolt/gmc_oilfilterlines1.jpg[/img]
[img]http://www.oldgmctrucks.com/photos/stovebolt/gmc_oilfilterlines2.jpg[/img]
#5025 10/24/2003 2:48 PM
it is a 1958 235 chevy.
