1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 26 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 26 | Fellas,
I have a 46 Chevy 2 ton and the shop manual says on page 4-10 to "pack w/ no. 2 1/2 soft, smooth cup grease." Why would you pack bearings that are immersed in 80/90 wt?
400case 1951 Ward LaFrance T120 1946 Chevy 2 ton 1936 International C35 1923 Sayers and Scovill
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 400case,
I don't have the manual so this is just a guess. Are these wheel bearings intended to be sealed from the axle tubes and differential, therefore need to be packed with grease. Maybe the seal has leaked and allowed gear lube in where it doesn't normally belong.
I didn't think the concept of gear lube lubricated rear wheel bearings came along until later than '46.
Stuart
| | | | | Joined: Dec 2008 Posts: 26 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 26 | The manual is not clear at all. When I pulled the drums/hubs there was zero evidence of grease on the bearings but there was 90 wt in them. That is a good point you made and I will have to look into it. Hopefully someone out there knows.
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Packing wheel bearings on a full-floater rear axle was a method of trying to keep from overloading hub seals with rear end lube. The grease-packed bearings also remained lubricated if the rear end grease level got low enough that it would not flow down the axle tubes and keep the hub bearings wet.
The big rigs we used to do electrical work on back in the 50's and 60's all had preventative maintenance programs that included rear wheel bearing packing at regular intervals. The service managers we dealt with insisted it resulted in fewer blown-out rear hub seals and less brake contamination with rear end grease if the bearings got packed regularly. Some of the hubs actually had an inner seal that fit around the axle shaft to keep the gear lube inboard of the hub bearings. Those hubs definitely needed grease-lubed bearings. Jerry
