1 members (jmoore),
124
Mod | | | Forums66 Topics128,093 Posts1,056,478 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 24 Member | | Member Joined: Dec 2001 Posts: 24 | ok its been 16 months and i cant remember where a line goes. 1958 235 on the right side of the head just above the number 3 and 4 spark plug there is a fitting. is there a line that goes from there to where the oil is pumped (other side of engine) to the oil filter? I have a place to hook 3 lines there, oil filter, oil pressure, and ???.
Thanks | | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | On my '58 235 the oil filter holes are both on the drivers side. Maybe someone drilled the other side for a pressure sender. Here's a pic of my motor where you can see the oil lines Photo here | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | 52GMC,,,, is your engine a 235 (Chevy) or a 228, 248, (GMC)??
| | | | | Joined: Dec 2001 Posts: 24 Member | | Member Joined: Dec 2001 Posts: 24 | | | |
