5 members (diseasel, Bill Hanlon, 59 fleet, Phak1, Wayne67vert), 109 guests, and 1 robot.
Topics128,035
Posts1,055,566
#501037 02/02/2009 8:19 PM
4D6
Offline
Apprentice
Apprentice
I have a 1955-57 235 in my '46 1/2 ton.. I am going to a rochester B manual choke carb so I can hook up the throttle and choke cables.. I found an intake in a local junk yard (good yard, 2nd generation and the guy hates computers).. The intake has the mount for the horn and the owner "thinks it was off a 1955 235". When I put the carburator on top, the manifold studs are about 3/8" closer together than the carburator holes. You bolters think this is a 235 manifild or a 216? By the way, I have an extra bee hive filter if anyone needs one...
Experience is the ability to recognize a mistake when you make it again....
4D6 #501056 02/02/2009 8:45 PM
sounds like a 216 intake. studs should be 2 15/16 for the 235 and 2 11/16 for the 216. if you can find a part # cast on the intake post it and someone may be able to give you a positive id. you can also go to http://chevy.oldcarmanualproject.com/ and find references to the part # yourself. good luck
big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
4D6 #501058 02/02/2009 8:45 PM
Maybe the manifold is off of a car. ohwell
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #501102 02/02/2009 10:08 PM
4D6
Offline
Apprentice
Apprentice
This guy had a 54 1/2 ton sitting in his yard. I was hoping it came from there.. I'll get the number
4D6 #501106 02/02/2009 10:27 PM
Most likely it is a 216 (car or truck) manifold or a pre-1950 235 (car or truck) manifold. The carburetor mounting bolts are closer together on those manifolds, in comparison to later 235 (1950-1962) and all 261 manifolds.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0266.htm
