1 members (Forty9),
64
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 Apprentice | | Apprentice Joined: Nov 2006 Posts: 33 | I have a 1955-57 235 in my '46 1/2 ton.. I am going to a rochester B manual choke carb so I can hook up the throttle and choke cables.. I found an intake in a local junk yard (good yard, 2nd generation and the guy hates computers).. The intake has the mount for the horn and the owner "thinks it was off a 1955 235". When I put the carburator on top, the manifold studs are about 3/8" closer together than the carburator holes. You bolters think this is a 235 manifild or a 216? By the way, I have an extra bee hive filter if anyone needs one...
Experience is the ability to recognize a mistake when you make it again....
| | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | sounds like a 216 intake. studs should be 2 15/16 for the 235 and 2 11/16 for the 216. if you can find a part # cast on the intake post it and someone may be able to give you a positive id. you can also go to http://chevy.oldcarmanualproject.com/ and find references to the part # yourself. good luck big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Maybe the manifold is off of a car.  | | | | | Joined: Nov 2006 Posts: 33 Apprentice | | Apprentice Joined: Nov 2006 Posts: 33 | This guy had a 54 1/2 ton sitting in his yard. I was hoping it came from there.. I'll get the number
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely it is a 216 (car or truck) manifold or a pre-1950 235 (car or truck) manifold. The carburetor mounting bolts are closer together on those manifolds, in comparison to later 235 (1950-1962) and all 261 manifolds. http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0266.htm | | |
