3 members (WICruiser, Phak1, 1 invisible),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | I have a 42 3/4 ton pickup with a Carter W-1 carb. It currently has a carter fuel filter with a fairly deep glass bowl that hangs down too low to mount the original horn on the bracket attatched to the intake manifold. Does anyone know if perhaps the original fuel filter was something other than the Carter? Something with a shallower bowl?
Thanks Chris
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Dec 2000 Posts: 14 Member | | Member Joined: Dec 2000 Posts: 14 | You should have a 216 so I believe the correct filter is a glass bowl on top of the fuel pump. The pump and filter are one integrated unit. | | |
#5010 03/25/2002 12:55 AM | Joined: Feb 2002 Posts: 15 Member | | Member Joined: Feb 2002 Posts: 15 | On my 47 1/2 ton, I have the exact same situation. I think the extra Carter filter was a factory option. If the filter is mounted perfectly vertical, then it interferes with the horn. On my truck the filter was always cocked slightly to make everything fit. I've seen reference to these filters in other places so I have to believe that "we got what we got". | | | | | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | 47ranchtruck is right.The fuel filter you are mentioning was an option when your stovebolt was new. The fuel filter is on the fuel pump (glass sediment type) the option was one mounted at the carb __________________________________________________ 37 Chevy 1/2 Ton
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
