1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#50086 09/13/2005 3:43 PM
Hello All,
We have a 56 Chevy 3200 longbed 1/2 ton truck, and are installing a 350 and 465 transmission from a 70 Chevy C/20. The 465 has a u-joint yoke attached to the output shaft, but we would like to use a one piece drive shaft which would require a slip yoke into the transmission. My question is (before I go trying to yank things apart), can we just remove the u-joint yoke and find a proper slip yoke to fit or would it require serious modifications to the transmission like changing the output shaft etc? Is there an easy solution or will we be stuck getting a different transmission or fabricating a two piece drive shaft?
Gene & Jr
horseballz
'56 Chevy 3200
'69 Ford F250
'68 Mustang Coupe/5.0 Roller/T5/Factory A/C
'03 Miata (Wifes Ride)
Why not use a driveshaft with the slip part dirrectly after the u joint on the transmission?
You know, the yoke about 7" long with internal splines, then the front end of the driveshaft has external splines on the end.
•1952 Chevrolet 3800 pickup
---All pictures---
Riding in the Passing Lane
A driveshaft shop can make up a driveshaft that will work. Grigg,s setup sounds like the best way.
1972 Chevy c10 Cheyenne Super
